Home AMX Resource Management Suite Software
RMS Enterprise configuration error database name.
When setting up RMS using the RMS Server configuration tool I'm getting the following error in the input field SQL Server Catalog(Database Name): the input field turns red and when I hover my mouse over the field it says "The database catalog is incompatible and cannot be used. Please choose a different catalog"
How do I create a compatible database catalog?
If you just enter the desired name of the catalog without creating it first it complains that the catalog doesn't exist, If I use SQL Server Management Studio and create a new database then I get the above error.
Windows Server 2008 Web edition
Java 6.0.37
Tomcat 6.0.36
SQL Express 10.0.1600.22
AMX RMS Server 4.0.52
RMS_Server.log
2012-11-06 08:03:16,389 ERROR [main] util.JDBCExceptionReporter [ ]- Invalid object name 'Version'.
2012-11-06 08:03:16,395 ERROR [main] spring.RmsLocalSessionFactoryBean [ ]- Caught hibernate exception.
org.hibernate.exception.SQLGrammarException: could not execute query
	at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java:92)
	at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:66)
	at org.hibernate.loader.Loader.doList(Loader.java:2536)
	at org.hibernate.loader.Loader.listIgnoreQueryCache(Loader.java:2276)
	at org.hibernate.loader.Loader.list(Loader.java:2271)
	at org.hibernate.loader.criteria.CriteriaLoader.list(CriteriaLoader.java:119)
	at org.hibernate.impl.SessionImpl.list(SessionImpl.java:1716)
	at org.hibernate.impl.CriteriaImpl.list(CriteriaImpl.java:347)
	at com.amx.rms.spring.RmsLocalSessionFactoryBean.verifyDatabaseVersion(RmsLocalSessionFactoryBean.java:100)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1546)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1487)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1419)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:518)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:455)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:293)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:290)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:192)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1327)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1085)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:516)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:425)
	at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:282)
	at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:204)
	at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4206)
	at org.apache.catalina.core.StandardContext.start(StandardContext.java:4705)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
	at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:943)
	at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:778)
	at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:504)
	at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
	at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
	at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
	at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
	at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
	at org.apache.catalina.core.StandardService.start(StandardService.java:525)
	at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Caused by: java.sql.SQLException: Invalid object name 'Version'.
	at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:368)
	at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2820)
	at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2258)
	at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:632)
	at net.sourceforge.jtds.jdbc.JtdsStatement.executeSQLQuery(JtdsStatement.java:477)
	at net.sourceforge.jtds.jdbc.JtdsPreparedStatement.executeQuery(JtdsPreparedStatement.java:778)
	at com.mchange.v2.c3p0.impl.NewProxyPreparedStatement.executeQuery(NewProxyPreparedStatement.java:76)
	at org.hibernate.jdbc.AbstractBatcher.getResultSet(AbstractBatcher.java:208)
	at org.hibernate.loader.Loader.getResultSet(Loader.java:1953)
	at org.hibernate.loader.Loader.doQuery(Loader.java:802)
	at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:274)
	at org.hibernate.loader.Loader.doList(Loader.java:2533)
	... 69 more
2012-11-06 08:03:16,463 ERROR [main] context.ContextLoader [ ]- Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsEntityInterceptor' defined in class path resource [applicationContext-hibernate.xml]: Cannot resolve reference to bean 'rmsMetadataValueDao' while setting bean property 'metadataValueDao'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsMetadataValueDao' defined in class path resource [applicationContext-hibernate.xml]: Cannot resolve reference to bean 'rmsSessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsSessionFactory' defined in class path resource [applicationContext-hibernate.xml]: Invocation of init method failed; nested exception is org.hibernate.exception.SQLGrammarException: could not execute query
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:328)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsMetadataValueDao' defined in class path resource [applicationContext-hibernate.xml]: Cannot resolve reference to bean 'rmsSessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsSessionFactory' defined in class path resource [applicationContext-hibernate.xml]: Invocation of init method failed; nested exception is org.hibernate.exception.SQLGrammarException: could not execute query
	... 39 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsSessionFactory' defined in class path resource [applicationContext-hibernate.xml]: Invocation of init method failed; nested exception is org.hibernate.exception.SQLGrammarException: could not execute query
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1422)
	... 49 more
Caused by: org.hibernate.exception.SQLGrammarException: could not execute query
	... 56 more
	... 69 more
2012-11-06 08:06:10,897 ERROR [main] util.JDBCExceptionReporter [ ]- Invalid object name 'Version'.
2012-11-06 08:06:10,926 ERROR [main] spring.RmsLocalSessionFactoryBean [ ]- Caught hibernate exception.
	... 69 more
2012-11-06 08:06:11,014 ERROR [main] context.ContextLoader [ ]- Context initialization failed
	... 39 more
	... 49 more
	... 56 more
	... 69 more
RMS_Server_Configuration_Tool.log
2012-11-05 15:29:40,790 INFO  [Thread-4] configuration.ProgressMonitorImpl - 0/100 : Mon Nov 05 15:29:40 CAT 2012 - Preparing database catalog install...
2012-11-05 15:29:40,813 INFO  [Thread-4] configuration.ProgressMonitorImpl - 5/100 : Done!
2012-11-05 15:29:40,819 INFO  [Thread-4] configuration.ProgressMonitorImpl - 5/100 : Mon Nov 05 15:29:40 CAT 2012 - Catalog already exists, skipping creation.
2012-11-05 15:29:40,820 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 :
2012-11-05 15:55:45,767 INFO  [Thread-4] configuration.ProgressMonitorImpl - 0/100 : Mon Nov 05 15:55:45 CAT 2012 - Preparing database catalog install...
2012-11-05 15:55:45,781 INFO  [Thread-4] configuration.ProgressMonitorImpl - 5/100 : Done!
2012-11-05 15:55:45,789 INFO  [Thread-4] configuration.ProgressMonitorImpl - 5/100 : Mon Nov 05 15:55:45 CAT 2012 - Catalog already exists, skipping creation.
2012-11-05 15:55:45,790 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 :
2012-11-05 15:55:46,093 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 : Mon Nov 05 15:55:46 CAT 2012 - Creating catalog tables...
2012-11-05 15:55:50,466 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 : Done!
2012-11-05 15:55:50,467 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 : Mon Nov 05 15:55:50 CAT 2012 - Creating scheduler tables...
2012-11-05 15:55:50,746 INFO  [Thread-4] configuration.ProgressMonitorImpl - 15/100 : Done!
2012-11-05 15:55:50,747 INFO  [Thread-4] configuration.ProgressMonitorImpl - 15/100 : Mon Nov 05 15:55:50 CAT 2012 - Creating system data...
2012-11-05 15:55:51,914 INFO  [Thread-4] configuration.ProgressMonitorImpl - 20/100 : Done!
2012-11-05 15:55:51,916 INFO  [Thread-4] configuration.ProgressMonitorImpl - 20/100 : Mon Nov 05 15:55:51 CAT 2012 - Creating default data...
2012-11-05 15:55:52,018 INFO  [Thread-4] configuration.ProgressMonitorImpl - 25/100 : Done!
2012-11-05 15:55:52,019 INFO  [Thread-4] configuration.ProgressMonitorImpl - 25/100 : Mon Nov 05 15:55:52 CAT 2012 - Creating asset type images...
2012-11-05 15:55:52,506 INFO  [Thread-4] configuration.ProgressMonitorImpl - 30/100 : Done!
2012-11-05 15:55:52,506 INFO  [Thread-4] configuration.ProgressMonitorImpl - 30/100 : Mon Nov 05 15:55:52 CAT 2012 - Creating model data...
2012-11-05 15:55:53,695 INFO  [Thread-4] configuration.ProgressMonitorImpl - 35/100 : Done!
2012-11-05 15:55:53,695 INFO  [Thread-4] configuration.ProgressMonitorImpl - 35/100 : Mon Nov 05 15:55:53 CAT 2012 - Updating Admin account...
2012-11-05 15:55:58,759 INFO  [Thread-4] configuration.ProgressMonitorImpl - 86/100 : Done!
2012-11-05 15:55:58,760 INFO  [Thread-4] configuration.ProgressMonitorImpl - 86/100 : Mon Nov 05 15:55:58 CAT 2012 - Updating user accounts...
2012-11-05 15:56:00,156 INFO  [Thread-4] configuration.ProgressMonitorImpl - 87/100 : Done!
2012-11-05 15:56:00,157 INFO  [Thread-4] configuration.ProgressMonitorImpl - 87/100 : Mon Nov 05 15:56:00 CAT 2012 - Creating access control lists...
2012-11-05 15:56:00,339 ERROR [Thread-4] core.SpringSecurityCoreVersion - Spring Major version '3' expected, but you are running with version: . Please check your classpath for unwanted jar files.
2012-11-05 15:56:12,993 INFO  [Thread-4] configuration.ProgressMonitorImpl - 90/100 : Done!
2012-11-05 15:56:12,993 INFO  [Thread-4] configuration.ProgressMonitorImpl - 90/100 : Mon Nov 05 15:56:12 CAT 2012 - Indexing database...
2012-11-05 15:56:13,789 INFO  [Thread-4] configuration.ProgressMonitorImpl - 95/100 : Done!
2012-11-05 15:56:13,789 INFO  [Thread-4] configuration.ProgressMonitorImpl - 95/100 : Mon Nov 05 15:56:13 CAT 2012 - Optimizing database...
2012-11-05 15:56:14,553 INFO  [Thread-4] configuration.ProgressMonitorImpl - 100/100 : Done!
Any pointers?
