Axcent...No control of axlink
I have encountered a problem with an old axcent3 controller.The axlink led is constantly On and does not blink.When I send a command to the controller it replies as " No Control of Axlink". It also does not connect through Access program and gives a message as Device connect error.
Any suggestions of what might have caused the problem amd how do I over come this...
--D
LED Full ON : Axcess program is not present, and there is no Axlink activity
If the master was in a error state the LED would be blinking three times per second
try connecting to the master with OpenAxcess and check to see if any
of your AxLink devices show up.
Could you be more specific when you say "sending commands through terminal"? what commands are you referring to?
Check your wiring to make sure that both ends are the same.
This can cause a solid green light.
SEth C. Olle
AMX PROGRAMMER
