Met-Ecom project
in AMX Hardware
Hi guys,
we're working on a project with this configuration:
- 8 apartments in a building, each apartment with it's own AMX system (controller, touch panels, etc);
- one entrance to be equipped with videointercom systems;
What is the sollution to be installed here, but not installing 8 different MET-ECOMs?
Is there any other compatible videointercom door unit?
Thank you!
Cristi
Thank you!
Cristi
Burrrrr! That's a bit cold. Well you're probably better off with a single MET-COM then plus one never knows when the X series will even support panel to panel video since I don't believe you can pull the video from one of them yet.
There was another thread:
http://www.amxforums.com/showthread.php?9054-Home-Gate-CCTV-Video-Intercom-amp-potential-VOIP-integration&highlight=doorphone
I don't know if this requires a SIP PBX for voice but it might be worth a read.
