CP3000 Series
Hi Everyone,
Is anyone else annoyed by the fact these devices don't toggle or get feedback? Does anyone have any 'insider' info if this will ever change?
Cameron
  • SheritonSheriton Posts: 1
    I'm pretty new to programming these devices so I'm not sure if the issue I've identified is the same as yours. I'm aware this post was nearly two years ago!
    I'm currently programming a CP-3017. For two of the buttons which act as power toggles, I want them start out red, flash for five seconds and turn green when pressed the first time. Then flash for five seconds and turn red when pressed the second time. Without the time delay, they work fine. With the time delay, they don't toggle - they only execute the level 1 script. I've got it to work by putting in manual toggle advances in each level for each button but this hardly seems like it's correct. Is this a known bug? I'm on firmware 1.2.57 which appears to be the latest on the website. It came with an earlier version which also had the same problem.
    Sheriton
