TASCAM CD-RW901 SL PROTOCOL PROBLEM
TASCAM PROTOCOL DOWNLOAD HERE
hi
i want some problem to TASCAM CD-RW 901 SL.
source code is it.
but it is do not controll.
where is the problem ??
appending the protocol
hi
DEFINE_DEVICE dvCDRec = 5001:1:1 //TASCAM_CD-RW901 SL dvTP = 10001:1:1 DEFINE_CONSTANT volatile integer CDREC_CONTROL_BTNS[]= { 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101 } DEFINE_EVENT DATA_EVENT[dvCDRec] { online: { send_command data.device,"'SET BAUD 38400,N,8,1 485 DISABLE'" send_command data.device,"'HSOFF'" } } BUTTON_EVENT[dvTP,CDREC_CONTROL_BTNS] { push: { switch( get_last( CDREC_CONTROL_BTNS ) ) { case 1: send_string dvCDRec,"$0A,'012',$0D" //PLAY case 2: send_string dvCDRec,"$0A,'01401',$0D" //PAUSE case 3: send_string dvCDRec,"$0A,'010',$0D" //STOP case 4: send_string dvCDRec,"$0A,'01601',$0D" //REW case 5: send_string dvCDRec,"$0A,'01600',$0D" //FF case 6: send_string dvCDRec,"$0A,'01A01',$0D" //SKIP REW case 7: send_string dvCDRec,"$0A,'01A00',$0D" //SKIP FF case 8: send_string dvCDRec,"$0A,'01301',$0D" //REC case 9: send_string dvCDRec,"$0A,'03700',$0D" //REPEAT OFF case 10: send_string dvCDRec,"$0A,'03701',$0D" //REPEAT SINGLE case 11: send_string dvCDRec,"$0A,'03701',$0D" //REPEAT ALL } } }
source code is it.
ah....
set baud rate is wrong?
thank you
try this setting use.
If baud rate is OK,
try as follows:
push:
switch( BUTTON.INPUT.CHANNEL)
case 91: send_string dvCDRec,"$0A,'012',$0D" //PLAY
case 92: send_string dvCDRec,"$0A,'01401',$0D" //PAUSE
case 93: send_string dvCDRec,"$0A,'010',$0D" //STOP
case 94: send_string dvCDRec,"$0A,'01601',$0D" //REW
case 95: send_string dvCDRec,"$0A,'01600',$0D" //FF
case 96: send_string dvCDRec,"$0A,'01A01',$0D" //SKIP REW
case 97: send_string dvCDRec,"$0A,'01A00',$0D" //SKIP FF
case 98: send_string dvCDRec,"$0A,'01301',$0D" //REC
case 99: send_string dvCDRec,"$0A,'03700',$0D" //REPEAT OFF
case 100: send_string dvCDRec,"$0A,'03701',$0D" //REPEAT SINGLE
case 101: send_string dvCDRec,"$0A,'03701',$0D" //REPEAT ALL
Just have a try.
If the problem is sovled,reply `.`
