Sony BluRay Protocol (BDP-BX59)?
A client picked up a Sony BDP-BX59 BluRay player at Costco or some big-box store. Does anyone know if this is controllable by IP and if there's a protocol document anywhere? I need to write a module for it.
Thanks!
John
  • I'm guessing it is IP controllable... I think I found the protocol here in case anyone else needs it:
    http://files.remotecentral.com/view/77-235-1/sony_bdp-cx7000es_blu-ray_disc_player.html
    So now the fun begins :)
  • John GonzalesJohn Gonzales Posts: 609
    Update:
    I didn't get a chance to test network controls on this device, so I just tossed IR control on it until I have access to the device.
    Here's the IR control info if anyone needs a simple way to control this BDP or similar. The code below assumes you've aligned your TP channels with the IR channels. The irl file (SONY0593.IRL) is in the AMX database.
    --John
    BUTTON_EVENT[tpBDP_SONY,0]		//Button Press - ANY
        PUSH:
        PULSE[dvBDP_SONY,button.input.channel]
    IR FIle: SONY0593.IRL
    Device:  SONY BDP-S790
    Remote:  RMT-B122A
    Compatible with BDP-BX59
    Match the Touchpanel Channels to the functions below:
    CH	FUNCTION
    1 	Play
    2 	Stop
    3 	Pause
    4 	Next >>|
    5 	Prev |<<
    6 	Scan >>
    7 	Scan <<
    9 	Power
    10 	0
    11 	1
    12 	2
    13 	3
    14 	4
    15 	5
    16 	6
    17 	7
    18 	8
    19 	9
    44 	Top Menu
    45 	Cursor ^
    46 	Cursor v
    47 	Cursor <
    48 	Cursor >
    49 	Enter
    54 	Return
    57 	Subtitle
    58 	Display
    80 	Open/Close
    89 	Audio
    111	Red
    112	Green
    113 Blue
    114 Yellow
    115 Pop Up Menu
    116 Input
    117 Home
    118 Options
    119 Netflix
    120 SEN
    121 3D
