dynamic images that reside on a local server
Does anyone know if it is possible to link a dynamic image window on a G4 panel to a PNG or JPG graphic file that resides on a local server rather than a website based graphic image??
And then in your code you can use sNetlinx.IPADDRESS as the IP address of the master.
I've got the NI master method down, but I would like give the client the ability to update a specific image on his server rather than logging into the master.
The NI master has an FTP server, which make this process easier.
Would this be a matter of just opening the necessary FTP ports on their server. Other than FTP or HTTP, I dont know of any method to direct the dynamic image to the panel. Maybe AMX will develop a general directory entry for this type of application of dynamic images.
I can do a G4 Computer Control window with no problem to the server,
but cannot get to a single specific graphic file. I realize the G4CC does not utilize the FTP protocol for communication, so this is probably not a good comparison.
Thanks for your replies.
This may be a stupid idea but you could install a lite web server on the local server and store the images there. Maybe someone else can come up with something better.
- Chip
I just downloaded and tested the AMX PictureFrame application and it will work perfectly for this particular project.
I rememer seeing this on the AMX web site a few years ago, but thought I would never utilize this type of program.
Unfortunately, it took me a few hours to remember that it existed, and where to find it.
Thanks again for the suggestions.
