MVP-900i battery fault
in AMX Hardware
I`m really the only one, I can`t believe.
This week 3 faulty battery`s pops out the housing of MVP-9000i.
One did push the touch overlay 4 mm out and all did destroy the backplane by taking out the nut.
Different locations, 2 are used in a MVP-WDS-9 and one in a MVP-TDS-9.
All panels are sold in 2011, what happens?
I get a dejavu of MVP-5xxx series.
For any of you guys running 9000i's that spend the majority of their life on charge I would highly recommend bringing them up to the latest firmware. There's a few nice features in there that relate to battery conditioning and will help prevent this from happening. It will also give you some analytics on battery health that will help you detect if this is going to happen.
VPN-CP, MVP-5xxxx, MVP-8400, MVP-9000. Incomprehensible!
In addition, the batteries are more expensive than a tablet. But why?
Why does the so expensive dockinstationen not regulate the charge right?
Hello AMX. have you an statement about this? Our clients are not amused about this!
Here you go. Better get your order in to Santa :P
