Home MODPEDIA - The Public Repository of Modules for Everyone
  • vincenvincen Posts: 526
    Thanks for module :) I would suggest to use first_local_ip_port_avalaible (check syntax, it's from memory ;) instead of passing dev parameter, it would make it yet more simple !
    First_local_port does not give you the 'next available' local port. It is essentially a constant 3 or 2 (I can't remember which) a bunch of modules with First_local_port are all going to and use the same IP port. I would not suggest hard coding a device in a module and forcing the rest of the world to just deal with it.
    ericmedley wrote: »
    +1. .
    my fault, made a confusion :(
