Module Guidance
In the attachment, I have created a Lutron Homeworks module which works perfectly in site, i want to know if there is any customization i need to make to the ui and comm module code for the Lutron homeworks so that it is more efficient and reusable. I haven't tried the available AMX modules for Homeworks so i may have wasted my time here.
Also i am working on another module in the same attachment for HVAC gateway. I need to pass values from the gateway ui module back to the touch panel, i wanted to know if there is any other way than sending command to a virtual device or passing the tp array as parameters. Right now the values are stored in a structure in the ui module.
