creating/using time variables
I'm trying to come up with a simple on/off timer for a system without using i-schedule or anything like that. I figured it should be easy to create my own time variable, and have an IF statement to match the system 'TIME' against that. I've got a working interface that manipulates system_on/system_off variables such as as CHAR Start_Time[8], so that they look like '12:05:00'. I stuck an IF in DEFINE_PROGRAM so that IF(TIME = Start_Time) it would set a flag, but it doesn't seem to work. Perhaps I'm missing something really simple, it just doesn't seem like this should be a difficult thing to do. Any suggestions?
Matt.
Matt.
There is nothing wrong with the time comparison IF statement that you noted in your message. It is identical to the samples provided in the online help for TIME and the construct is used in the AMX SunriseSunset axi file for determining when to check for daylight savings time.
One possibility is that your mainline code (DEFINE_PROGRAM) is not executing every second and therefore when the check is executed, the time does not match. This could be the case if you have a system with a lot of events, a system with a lot of mainline code that takes a while to run, or a combination of both.
Keep in mind that you could modify the TIME string you store in Start_Time such that Start_Time[8] = '?' and then use COMPARE_STRING to compare the current time in mainline to Start_Time. The '?' is a wildcard comparison character and therefore the conditional would match the time down to a 10 second interval (i.e. 12:05:00 -> 12:05:09 using 12:05:0?). I use this type of construct frequently just in case mainline was delayed in running by events such that one or more seconds went by before it was executed.
Hope this helps --
Reese
What I do in such applications is to separate the time or date elements into numeric values:
INTEGER nMyHour
INTEGER nMyMinute
INTEGER nMySecond
nMyHour = TIME_TO_HOUR(TIME)
nMyMinute = TIME_TO_MINUTE(TIME)
nMySecond = TIME_TO_SECOND(TIME)
Almost the same with DATE:
INTEGER nMyDay
INTEGER nMyMonth
INTEGER nMyYear
nMyDay = DATE_TO_DAY(DATE)
nMyMonth = DATE_TO_MONTH(DATE)
nMyYear = DATE_TO_YEAR(DATE)
Marc,
You are correct that WILDCARDs do not work in Netlinx if used directly in a comparison statement such as:
IF(TIME = '12:00:0?') { // works in Axcess but not in Netlinx! }This apparently used to work in Axcess but is one of the constructs that needs to be converted during a migration to Netlinx since it does not work in Netlinx. However, WILDCARDs that are utilized in conjunction with the COMPARE_STRING() function work fine. I have tested it (and have modules that use it) and it does work. This is why I pointed out to Matt that COMPARE_STRING() was required if the WILDCARD construct was to be used -- it could not be substituted directly in the IF comparison and work correctly in Netlinx.Also, see AMX TechNote 555 which explains the difference between Axcess and Netlinx with respect to WILDCARD handling.
Reese
I set mine to COMPARE_STRING(time == '12:30:??'), this way I know it will only trigger one time.
You can test this by adding a nCOUNT++ in the statement and watch it count up, every increase in nCOUNT would be another command sent. This is also effected by how many lines of code are in the DEFINE_PROGRAM section, the more code less repeats.
This works ok for me.
So, instead of simply testing a time, I keep a persistent array of event flags and test for a time range instead. I'll break the time string into hours and minutes using TIME_TO_HOUR() and TIME_TO_MINUTE(), then test if the current time is greater than those values. If it is, and the flag is not set, then set the flag and fire the event. The set flag prevents it from firing twice, and if the system reboots at noon, you won't lose your 7AM event. All tests are done in a repeating timeline, usually run more than once a minute, depending on how precise I need it to be. Also in that timeline, I test the date, and if the date has changed, reset all the flags to false so the events will happen again on a new day.
Hopefully somedoby can help me, I have a similar issue, I have a NI-700 and NI-2100. I asked for help here on the forum, and tried to load the code and it turns it off, by the projector gets into stand by instead of turn it off. Panasonic 80U and 60U. Anyway here is the code first try
(* FORCE PROJECTOR TURN OFF *****************************************************)
IF (COMPARE_STRING(TIME,'16:20:0?'))
wait 1810
SEND_STRING dvPROJ,"$02,'POF',$03"
proj_off=0
here is the other
(*********************************Auto Shutdown *****************************)
IF (COMPARE_STRING(TIME,'22:00:00'))
SEND_STRING dvProjector,"$02,'POF',$03";
I was reading some threads and this is what I found. Click on the link
http://www.amxforums.com/showthread.php?3470-Commands-at-Certain-Times&highlight=COMPARE_STRING
Finally I figure out how to make my projectors turn off, after reading and reading and too many test's, I got it. Thank God for this forum and genorous people for posting their solutions.
here is the code from B_Clements
Define_Program
IF (TIME='22:00:00') // Execute everyday at 10 PM
Wait 11
fnSystem_Power(nOff) // Excute system off function
Here is my code for Panasonic projector
Define_Program
******************Shutdown**************)
IF (TIME='13:34:00')
wait 11
Again I thank to everybody for the post
