DATA via COMM port
Good morning, Masters!
What should be procedure for correct data processing?
I want to analyze string coming from device via COMM port.
If the answer has not come, it is necessary to repeat request or to do something else.
It will be more clear if I give a code.
Notwithstanding what time has expired a body of WAIT is never started so timeOut is FALSE always.
And buffer=='' too. It is independent of the answer comes or not.
PROGRAM_NAME='Main'
DEFINE_DEVICE
dvDEVICE = 5001:1:1;
dvIO = 5001:9:1;
DEFINE_VARIABLE
integer timeOut;
char buffer[1024];
DEFINE_EVENT
CHANNEL_EVENT [dvIO,1]
ON:
timeOut=FALSE;
SEND_STRING dvDEVICE,"$02,'0','7','C','D','F',$03"
WAIT 10
timeOut=TRUE; //There is no answer from device within sec
while (timeOut==FALSE OR LENGTH_STRING(buffer)); // just waiting answer
if (timeOut==TRUE)
SEND_STRING 0,'Communication problem';
else
SEND_STRING 0,"'Got answer =',buffer";
DEFINE_START
CREATE_BUFFER dvDEVICE,Buffer;
Thanks.. And Sorry for my ugly English as always.
Alex.
PROGRAM_NAME='Main'
DEFINE_DEVICE
dvIO = 5001:9:1;
DEFINE_VARIABLE
integer timeOut;
char buffer[1024];
DEFINE_EVENT
ON:
timeOut=FALSE;
WAIT 10
if (timeOut==TRUE)
else
DEFINE_START
Alex.
Ummm, I think what you need to do is something like this:
PROGRAM_NAME='Main' DEFINE_CONSTANT INTEGER TIMEOUTTIME = 100 //10th of a second CHAR START_OF_RESPONSE[2] = {$02,'R'} CHAR END_OF_RESPONSE[1] = {$03} DEFINE_DEVICE dvDEVICE = 5001:1:1; dvIO = 5001:9:1; DEFINE_VARIABLE integer timeOut; char buffer[1024]; DEFINE_CALL 'SEND DATA' { SEND_STRING dvDEVICE,"$02,'0','7','C','D','F',$03" WAIT TIMEOUTTIME 'RESEND DATA' CALL 'SEND DATA' } DEFINE_EVENT CHANNEL_EVENT [dvIO,1] { ON: { CALL 'SEND DATA' } } DATA_EVENT[dvDEVICE] { STRING: { STACK_VAR CHAR RESPONSE[50] STACK_VAR INTEGER EXPECTED_RESPONSE WHILE(FIND_STRING(buffer,START_OF_RESPONSE,1) && FIND_STRING(buffer,END_OF_RESPONSE,2)) { RESPONSE = REMOVE_STRING(buffer,END_OF_RESPONSE,2) //HANDLE STRING PROCESSING HERE (Set EXPECTED_RESPONSE to TRUE if response is as expected) } IF(EXPECTED_RESPONSE) //cancel sending the command again CANCEL_WAIT 'RESEND DATA' ELSE //reset timer { CANCEL_WAIT 'RESEND DATA' WAIT TIMEOUTTIME 'RESEND DATA' CALL 'SEND DATA' } } } DEFINE_START CREATE_BUFFER dvDEVICE,Buffer;I think that will do what you want, but you need to make sure that you set the timeout high enough to make sure you aren't flooding the serial port.
If "CHANNEL_EVENT [dvIO,1]" triggers the "CALL 'SEND DATA'" and no response is sent from the "dvDEVICE", it would go in to a forever loop.
I would just resend the "CALL 'SEND DATA'" command only if I get a response from the "dvDEVICE" and I know that it is ready to receive a new command.
DATA_EVENT[dvDEVICE] { STRING: { STACK_VAR CHAR RESPONSE[50] WHILE(FIND_STRING(buffer,START_OF_RESPONSE,1) && FIND_STRING(buffer,END_OF_RESPONSE,2)) { RESPONSE = REMOVE_STRING(buffer,END_OF_RESPONSE,2) //HANDLE STRING PROCESSING HERE (Set CALL 'SEND DATA' } } }I agree. My intentions were to give a starting place, not to write a full comm module for the device. I suppose I really should have included a timeout or in the least coded it to resend the command every 10 seconds for the first 5 attempts, then only resend every minute or two until communication is re-established.
Alex,
If you need any help with the timeout portion, just ask and I'll see what I can do. Also, it would be really helpful to know the device you are working with and a few more specifics regarding the communication protocol.
That is what I thought, I just posted it in case someone tryed your code and wasn't connected to the device.
Gary
http://www.amx.com/techsupport/PDNTechNote.asp?id=616
The last example in the tech note is one I highly recommend if the data response packet is a reasonable size.
Brian
