Odd structure "bug"
I noticed the other day that the compiler doesn't care if you declare a structure type without defining it. In define_variable you can put:
volatile _Fubar fubar
and even though there is no _Fubar in define_type, the compiler doesn't care. Rather odd.
  • I talked to Mark Gillner, AMX Canada Trainer, and he figures the compiler will
    simply ignore fubar and _Fubar will be an Integer.
    compiler interprets to
    VOLATILE Integer _Fubar;
    a_riot42 wrote: »
    There is no structure type involved here.
    I don't think that is true.
    I think the compiler will see _Fubar as a VOLATILE INTEGER
    and
    the compiler will see fubar as a NON_VOLATILE INTEGER
    Edit:
    To further clarify
    DEFINE_VARIABLE
    Will be seen as:
    DEFINE_VARIABLE
    volatile _Fubar	// defaults to INTEGER
    fubar			// defaults to NON_VOLATILE INTEGER
    Yes the compiler must see it as an integer. Without the structure in define_type it has no way of knowing you are trying to declare a structure rather than a default integer. I had a typo in my structure declaration and was surprised that the compiler didn't complain, but what you say makes perfect sense.
  • Ah yes, that makes perfect sense.
    DEFINE_VARIABLE
    Thank you for the clarification.
