Need help with RS 485 and Dado Door
in AMX Hardware
Is anyone familiar with the Dado Door product? Their installation manual says that they only use two pins for RS485 communication, "RJ45 pins: A=1, B=2, 3-8 unused." Am I right that this isn't typical? I'm wondering which would be the corresponding pins on an NI-4100 serial port.
Also, here is my usual Data Event handler for initializing serial ports, should I do it differently for this product? (Yes, the baud etc. are from their programming manual.)
DATA_EVENT [dvDADO_DOOR] //INITIALIZE RS232 PORT FOR DADO DOOR
{ ONLINE:
{SEND_COMMAND DATA.DEVICE,'SET BAUD 9600,N,8,1 485 ENABLE'
SEND_COMMAND DATA.DEVICE,'HSOFF'
Page 25.
Yes.
RS485 is half-duplex. Transmit and receive are on the same wires.
I don't understand how it works with just two wires, though. It's balanced and should use two wires plus ground, as I understand it.
