MVP-8400 Firmware Update Issue with PEAP Authentication
I have an issue where running any firmware greater than 2.84.18 and the panel has trouble staying connected to our wi-fi network that uses PEAP Authentication. Firmware 2.84.18 works fine anything newer does not. The issue is that the panel will connect to the network and then after a minute or so loses all wireless connectivity. If I do a network scan and then cancel it will reconnect and stay connected until the next reboot.
This happens across several panels and different wireless cards.
Anyone else have a similar issue and were you able to find a solution?
