file not found error
after compiling I get the following message:
Starting NetLinx Compile - Version[2.5.2.20] [06-18-2013 10:12:36]
C:\Users\Auvicomm\Desktop\dental btn daegu cr\AMX Files\Device Files\Biamp Audia Flex Main.axs
ERROR: C:\Users\Auvicomm\Desktop\dental btn daegu cr\AMX Files\Device Files\Biamp Audia Flex Main.tko(0): L20206: File [Biamp Audia Flex, Preset UI.tko] could not be found
C:\Users\Auvicomm\Desktop\dental btn daegu cr\AMX Files\Device Files\Biamp Audia Flex Main.axs - 1 error(s), 0 warning(s)
NetLinx Compile Complete [06-18-2013 10:12:36]
I can find it in the directory location so am not sure how to fix the problem.
You have to do a build system, sounds like the NetLinx UI modules need compiling.
thanks. done that didn't fix it.
"C:\Users\Auvicomm\Desktop\dental btn daegu cr\AMX Files\Device Files\Biamp Audia Flex, Preset UI.axs"
Do a search for:
"C:\Users\Auvicomm\Desktop\dental btn daegu cr\AMX Files\Device Files\Biamp Audia Flex, Preset UI.*"
For me, the hard and fast rule is to have a sub-folder on a data volume that's for work and compiling.
The folder naming should be simple (ie 8.3) and never use spaces. I'm probably sounding like a DOS dinosaur, but historically, sticking to 8.3 naming and no spaces has also proven to avoid hyperlinking and compiling errors.
I know what I'm saying may not help you now, but maybe moving your project to a more reliable folder may help you.
(edit: I just saw someone place a comma in the name as well. Do not complicate file/foler naming with punctuation, as well as sticking to 8.3).
-John
http://technet.microsoft.com/en-us/sysinternals/default
AccessEnum lets you scan a directory examine the NT access rights and if run from your profile should show if you can access the required files.
FileMon should be started before compiling and then after the compile fails, stop it and run filters across the output to see where the issue lies.
There is a lot of other utilities in the sysinternals suite that are great diagnosis tools and the nice thing is that they are all free.
I agree with the other posters however that the file location (in mydocs) or punctuation (comma) might be a very likely cause in this instance.
I can say with reasonable certainty that path length is not the issue at least, as I have workspaces with paths that long or longer. Back when I first started programming I vaguely recall managing to choke NetLinx on an excessively long path once, but I haven't had that problem for a long time so I assume they must have upped the supported length at some point.
Long file names have been in Windows for almost 20 years at this point and My Documents has been the appropriate place to store user files in Windows for 17 years or so. Any programs or tools that don't properly deal with them or the long paths they make inevitable deserve to be publicly shamed at this point imo. (let me take this opportunity to shame Brand C's VTProE for breaking in really weird ways if your file's path is too long) Nearly two decades should be enough time to adapt.
Now, copy this project to a new project and it breaks down. I then have to reassemble the whole thing in the project to gt rid of the error.
