Incoming calls on CSG gateway are one continuous ring.
in AMX Hardware
I am facing this issue with Cisco SIP gateway also where the incoming call is one continuous ring until a user hangs up or ignore/answer. Since both SIP gateways use Asterisk, i am not sure how to resolve this issue.
I have put the ring timeout in options in the sip server as 5 seconds but no use.
Ringgroup call timeouts work for 10 seconds.
Here is a similar issue mentioned in the asterisk forums.
http://forums.digium.com/viewtopic.php?p=128415&sid=d64f74ff246963a4b4b798a67a40c1f0
