EXB-IRS4 and "TO" commands
cma
It appears that a standard "TO" IR command does not function the same on an EXB-IRS4?? Anyone else notice this?
Trying to get push and hold scrolling to work on a couple devices and it appears that when you use a "TO" command the IR code gets sent once and that's it.
Current job it works fine on Blurays IR wired to the NI-3100, but only power commands work on players wired to ICSLan IRS4. Tried changing from TO to stacked pulse with no luck.
It does work for power on/off but not for anything else.
