How many Threads is too many?
In ongoing discussions with AMX there seems to be an issue if to many THreads are created in Duet. But, there does not seem to be a clear picture of how many is too many. Using Thread.activeCount() it seems that there are approximately 18 threads running with a single module running. I am writing a program that will be opening many ip connections concurrently, with each connection running in its own Thread. Anybody have any thoughts/experience on this topic?
For the number of thread, I've never had any problem: I use up to 2 thread per connection and some of our running systems have more than 40 threads living at the same time in the same module.
I've never tried to stress test a controller to see how many IO threads can be spawn safely, but in my opinion you will not have any problems.
If you have to deal with a high number of IP (or other blocking) connections, making some of them non-persistent can reduce the system resources that are used. For example, PJLink projectors only respond to queries, so after I receive the response to a query I close the socket. The projector can’t send any data I didn’t ask for, so I won’t miss anything by closing the connection, and now those resources are freed up to go query the next device. The “command” design pattern is helpful for this kind of thing.
