Tascam DV-D01U help
I will admit I am probably missing something dumb, but this location seems to provide nothing but headaches and I am at my wits end.
Finally convinced this school to upgrade from an old Axcess system to a new Netlinx. Everything is working as it should except the tascam dvd player which I seem to have zero control over, so it leads me to being something so dumb I have overlooked it 100 times.
None of the Send Strings are working. I see the TX light blink. I get notification the string was sent:
Line 413 (11:09:55):: String To [5001:4:1]-[$02,$3E,$53,$4B,$50,$63,$47,$30,$30,$32,$20,$20,$20,$20,$45,$38,]
Line 414 (11:09:55):: String To [5001:4:1]-[$03]
The string is defined in the constants
GOTK2_STR = "$02,$3E,$53,$4B,$50,$63,$47,$30,$30,$32,$20,$20,$20,$20,$45,$38,$03"
And in the program:
PUSH[TP,133] (* CALL TK2 TO PLAY MISSION 1 *)
ON[TP,133]
ON[TP,80] (* DVD PLAY BUTTON *)
SEND_STRING DVD,"GOTK2_STR"
SYSTEM_CALL [SWT] 'SWT9' (SWT,6, 9, 1) (* DVD TO TP *)
That is one example of code for this device.
What am I missing? I am sure it'll be double face palm worthy when I'm shown, this is just becoming one of those I need a fresh set of eyes moments. Thanks for taking a look.
    Where did you set the baud rate for the RS-232 port.
    If you have it under define_start, it needs to be moved to the online event for the comm port.
  • tweekendtweekend Posts: 15
    I have the following under Define Event:
    DATA_EVENT [DVD]
    ONLINE:
    WAIT 60
    SEND_COMMAND DVD,'SET BAUD 9600,N,8,1 485 DISABLE'
    SEND_COMMAND DVD,'HSOFF'
    Joe Hebert wrote: »
    How about the cable?
    Check out the first 2 Qs in the forum faq:
    http://www.amxforums.com/showthread.php?4085-Forum-FAQs
    BTW - you don't need the wait for the send_command in the online event but it won't hurt anything.
    Double Face Palm for sure. Thank you for the extra brain. Bad cable, how did I not check. Tried three different Tascams, with the same issue which kept pushing me to being something I messed up in the programming. How I didn't do the basic and swap a cable first.
    Thank you very much, I needed a fresh look. And thank you for the link, booked marked to remind me of the basic checks and for passing on in the future.
    You're welcome.
    Glad you got it working.
