Master to Master String - Gibberish
I have a master to master connection and I can see the String From correctly on the second master. However when I'm assigning that to a variable via DATA.TEXT on Master 2 I am just get gibberish. The firmware is the same on both units. Why would this be?
    Check the variable type you are assigning as your string buffer. My guess is that the string coming in as not ASCII. So, the hex values coming in are being represented as ASCII.
  • jabramsonjabramson Posts: 106
    It is a hex string coming in. How do I convert that to something useful? I only see HEXTOI, but this does contain ASCII as well.
  • dhasleydhasley Posts: 1
    If you want to just look at it live, the debugger in NetLinx Studio can be set to display the hex values. If you want to print it out to the terminal or elsewhere, you'll need to write something to change each byte to an ASCII string, e.g., convert the following single example byte: "$02" into a three byte ASCII string: '$02' (shown in hex: "$24,$30,$32"), then send it to the terminal. Here's an example:
    DEFINE_FUNCTION CHAR[100] fnStringToHex(CHAR cInString[])
    LOCAL_VAR CHAR cTempByte;
    LOCAL_VAR CHAR cTempString[2];
    LOCAL_VAR CHAR cOutString[100];
    CLEAR_BUFFER cOutString;
    WHILE(LENGTH_ARRAY(cInString))
    cTempByte = GET_BUFFER_CHAR(cInString); //Grab one byte from the input
    cTempString = ITOHEX(cTempByte); //Convert that one byte to a two byte string representing the hex value in ASCII
    IF(LENGTH_ARRAY(cTempString) == 2)
    cOutString = "cOutString,'$',cTempString,','"; //Add a dollar sign to the beginning and a comma to the end, for readability
    ELSE IF(LENGTH_ARRAY(cTempString) == 1)
    cOutString = "cOutString,'$0',cTempString,','"; //Pad with a zero if the output of ITOHEX was ony one character long
    SET_LENGTH_ARRAY(cOutString,LENGTH_ARRAY(cOutString) - 1); //Discard the last comma
    cOutString = "'"',cOutString,'"'"; //Add some quotes, because I want them in the string I'll be passing to my terminal
    RETURN cOutString; //Return the finished string - enjoy!
    jabramson wrote: »
    Well, what's not useful about hex? For example, let's make up a protocol for the discussion. Let's say the string coming back is a mix of hex and ascii.
    Let's say the box comes back with the following string for a change in volume.
    "$01,$01,$02,DVD:45,$FF" The first threer cells are bytes telling you the
    unit ID
    Power Stat
    Zone Id
    The given ASCII text name of the zone
    The ASCII value of the volume
    and the $FF is the string terminator.
    Treat cells 1 through 3 as integers
    So unit ID is something like..
    integer Unit_id;
    integer Power_Stat;
    integer Zone_id;
    Unit_ID=buffer[1]
    Power_Stat=buffer[2]
    Zone_id=buffer[3]
    there are many ways to do this and this is just an example for the sake of the discussion.
    To get the text out just strip out the first three cells of the buffer. use Right String or Get_Buffer_Char or whatever. or search for the first hex value in the string over $20 which is where the ASCII chars start.
    So something like.
    DEFINE_Variable
    Zone_Name[10]
    GET_BUFFER_CHAR(buffer)// strips off first buffer cell
    GET_BUFFER_CHAR(buffer)// next cell
    Zone_Name=remove_string(buffer,':',1) // Zone_Name will be "DVD:"
    // then strip off the last ":" and you'll have your text.
    now all that's left is "45,$FF"
    so to get the volume from the ascii value is easy-peasy.
    DEFINE_VARIABLE
    integer current_vol
    current_vol=atoi(buffer)
    Hope that helps.
    e
    FORMAT plug
    dhasley wrote: »
    As the official spokesman for FORMAT, I feel compelled to point out that the variable cTempString and this code:
    Can be replaced with this 1 line using the underappreciated FORMAT command:
    cOutString = "cOutString,FORMAT('$%02X,',cTempByte)"
    Exit stage left...
