WAIT 0
nicholasjames
While writing a function that called a WAIT with a variable for the time it occurred to me I didn't know what would happen if that time was 0. I hypothesized that it would evaluate to "don't wait and run the code now" but it does in fact get placed on the WAIT list. Since it has a timeout of 0 it always runs immediately following the event that called it.
Here's a hastily written and untested example using it to insert a line between each event's diagnostic text:
DEFINE_DEVICE dvTP = 10001:1:0; vdvTest = 33001:1:0; DEFINE_FUNCTION Debug(CHAR sText[]) { SEND_STRING 0, "sText"; WAIT 0 'DEBUG_BREAK' { SEND_STRING 0, "'----------------'"; } } DEFINE_EVENT BUTTON_EVENT[dvTP, 1] { RELEASE: { ON[vdvTest, 1]; ON[vdvTest, 2]; } } CHANNEL_EVENT[vdvTest, 0] { ON: { Debug("'Channel ',ITOA (CHANNEL.CHANNEL)"); Debug("'Another line'"); } }Diagnostics:
01: Channel 1 02: Another line 03: ---------------- 04: Channel 2 05: Another line 06: ----------------
For example if you want to set a channel high on a virtual device (and cause something to happen) before you go and run some long function you're out of luck. The long-running function has to complete before the event handler ends. Then your vd event handler can go ahead and do its thing.
So a short wait does the trick here too:
Unfortunately though, from the NetLinx help file:
So it may actually loop round and run in ~1.3 years. Wouldn't that be a fun bug to diagnose.
Don't know what that means if the wait is in an event?
You're welcome.
Don't forget....
That's correct. WAITs jsut pass their code block into a holding area which is checked every pass of mainline. When the timer has expired for a particular WAIT, that pass of mainline will execute the code. Since WAIT 0 is essentially expired immediately, the very next pass of mainline fires it.
Putting a WAIT in an event does the same thing. WHen the event fires, the WAIT goes into holding until it's timer expires. That's why you can't use STACK variables in a WAIT inside and event; the variable is meaningless outside the event, and the WAIT does all it's actual functioning in mainline, not in the event itself.
Just to be clear, the WAIT list (including any other timed event) is checked between each event in the queue, as well as each time mainline runs.
FIG. 1 Message and Mainline Processing in the NetLinx System [size=-2](page 2 of the NetLinx Language Reference Guide)[/size]
So, referring to my example at the top, if I also added this:
my output (which I just realized was not correct in the first example) would be something like:
While refining/testing logging using this feature, I discovered something interesting. My WAIT 0 new line wasn't occurring after each event handler like I assumed from that graphic above, but after every handler for each event.
I had multiple UI modules for one COMM and I expected to see this:
But instead got this:
So when an event fires, NetLinx runs ALL handlers for that specific event and then checks the waiting list, running any waits that may have expired while running each of those events. Knowing that isn't a game changer, but it could help explain any odd "synchronization" issues between modules.
Interesting, thanks for the info.
