Home AMX Technical Discussion
Aprilaire 8800...
Hello all, hopefully someone has an answer for this....don't want to be blowing stuff up.
First, I have acquired a brand new Aprilaire 8800 TStat.
Can an 8800 (since my house only has one stat) be wired directly to a processor via RS-485? If so, what would that connection be?
If I do need a protocol adapter, will the older style red 8811 style work with the 8800? I can get a deal on one of those if needed.
Thanks to anyone that can help!!!!!!
    Yes, we do it direct all the time.
  • Thanks John!
    Last question...
    When directly connecting the processor to the TStat, does ground of the 485 get connected to the "C" terminal of the TStat?
    I'm pretty sure that C connection is for a power common and not a signal common. I've never had to hook it up, but then again I have never hooked up just one stat, and have been running through a disty panel.
  • Thanks Dave. Yes, the C is for power common which is what is confusing me...
    As far as I can tell, I connect A+,A-,B+, and B- of the termostat to TX+,TX-,RX+, and RX- on the serial port of the processor. But what about ground? Is ground not needed because of RX- and TX-?
    Thanks!!!!
    DB-9 Pins On NI for Aprilaire 8870/8800 (RS-422, not 485)
    1 B-
    2
    3
    4 A+
    5 REF
    6 B+
    7
    8
    9 A-
  • Thanks John. That's what I have too but my only question is where does "REF" get connected on the TStat?
    Thanks for helping me get this figured out!
    As I mentioned, you don't need to. The TX/RX +/- are balanced signals, and shouldn't need a signal ground. The only time I have ever used the REF terminal was for a drain on the cable's shield, and then I only connected it on one end.
  • Thanks all! Everything is working just fine. Still have some fine tuning but besides that I'm good!
