Home AMX Technical Discussion
Macbook Pro, Parallels 8 and Netlinx Studio
Hi,
I'm having an issue with a Mac Book Pro 13", Parallels 8 and Netlinx Studio.
If I create a blank source file it compiles fine.
If I open a Workspace (that compiles on my dedicated windows 7 machine fine) and compile it the compiler gives me "Internal Error: Major system error occurred during code generation"
I'm not overly Mac savvy so any help would be good.
Cheers!
    Did you let Web Update install NS? If not you might try that.
  • d_gavind_gavin Posts: 21
    Yeah I did it all through Web Update.
  • champchamp Posts: 261
    NS compiler has troubles finding files when they are in your My Documents directory because the file path doesn't start with a drive letter.
    Make an AMX directory at the root of a dricve and put your source code in there then try again.
    Another possibility is your code, any time I have seen Major System Error on compile it turned out to be a function defined twice.
  • nickmnickm Posts: 152
    Also, do not store code files in network drives or directories that are actively synchronized with cloud services such as SugarSync or Dropbox.
