MET-ECOM-D resetting to factory settings automatically
in AMX Hardware
I have two sites where the MET-ECOM-D automatically resets to factory settings and then it will work for weeks without any issue.
Both sites are having temperature range of 50 C which is below the maximum limit of 60 C which is the operating temperature of the device.
Both sites are using the latest firmware of 1.01.20. I heard there is a hot fix available, i will try to update to that firmware and check the issue.
I tried replacing the MET-ECOM-D but the new units also has the same issue. Has anyone faced a similar issue.
I have a spare unit available and so i will replace this main entrance unit and observe.
have recently battled with 4 Met ecoms that worked fine for a year. The big concern was that one was around 75 feet past POE maximum distance. After a S@*%load of wasted hours trying to troubleshoot, it appeared to be the K-Scape module tying up ports. So I suggest RS-232 for K-Scape, and load Met-Ecom firmware locally not over distance
