NI-3101-SIG not connecting after rebooting.
in AMX Hardware
I got 9 NI-3101 processors at a site with master to master and route mode direct mode set. Some times the masters when its rebooted, it takes a long time to come online on the online tree. I am able to telnet to the processor at those times and i see that its trying to connect to the other masters,etc. Please see attached file below.
Now if i remove the network cable and reboot the processor, i can see it come online on the online tree when i place the network cable after about five minutes. I am not sure if its a firmware (1.30.8 and 3.60.453). The ethernet mode set in the processors is 100 full after consulting with the network admin at site. Please guide if you have faced a similar issue.
1. Upgrade only the duet master firmware to the latest on the website (4.1.373)
2. Make sure that no master to master devices are listed in the define_device unless its used in the masters.
