Playlist Itunes or other player (for PC or Mac)
Dear Members,
After reading many post, it seems so far that the only solution to control an audio player (itunes for example) (on a mac or pc) is a module from Autonomic (iTunes module for ******** and AMX)
Our need is to have a two way communication with an audio player hosted on a PC (or mac) in order to select, start and stop playlist, next, previous on track and having feed back on the track, and general volume control (Art Cover display would be a must
Unfortunately, after getting in touch with Autonomic, they do not provide any "test" solution, so i wanted if :
1/ Any of you can provide feedback on this solution from Autonomic
2/ If there is an alternative solution
Best regards.
Alexandre.
Best regards.
Alexandre.
I ended up using a bunch of rack-mounted Squeezebox touches, using the slimserver module. The Squeezebox Touches automatically sync w/ iTunes songs/lists and it all works fabulously w/ 2-way control to TPs, KPs, RCs. Unfortunately, Logitech has EOLed the Touches, but I'd use an old Touch over a new Autonomic anyday.
Oddly designed UI that follow no standard.
Half-baked API that clearly were pushed out to meet an arbitrary marketing deadline.
Kludgey workarounds to get them to function.
Capricious manufacturers who retool their product just to make a new box to sell
Lots of time required to develop an implementation that's stable
Short lifespan.
People are pretty used to things like the Apple interface and the like. I tend to lethem use their normal interface and just make sure the audio input is hot.
Yeah, the ReQuest has done very well. There was the whole Hulu thing and their heavy reliance on icons in their GUI that made it next to impossible to import their TP into a project. But, yes it was pretty good. Kaleidescape too. Both not to bad.
