Lutron QS connection
Has anyone had an issue connecting to a Lutron QS system. I can connect using telnet but not through AMX - I keep getting bad login. It is the same logic as the RA2 which works fine. I am using AMX firmware version 4.363.
Thanks!!!
Thanks!!!
What login are you using? I think that if the lighting designer is still logged in it disables the integrator account. I've had to reboot the QS system after changes are made. Not sure if that's still the case or not.
'integration,jetski'
to the login prompt, where now you have to reply individually to the prompts (login: and password: ).
Maybe?
Hi Paul
I can login with telnet every time. It's the same login logic as RA2. ???
- Gary
Hey Chad
It's same as RA2 so login and password are separate. Maybe it's an AMX issue? I am using a beta firmware, but doesn't make sense.
-Gary
I will in a week or so. The system is a redo after abandonment, and one of the problems was the AMX and Lutron systems were having issues communicating. I haven't logged in to this mess yet, but when I do I can see what's up. I am going to use the AMX Duet QS module, and don't expect any comm issues, as I have many older Lutron systems running fine with older AMX Duet modules.
We rolled our own, based on our RA2. They use different offsets on ID's but are otherwise nearly alike.
Hi John
RA2 is not an issue, have you done it with the new version of QS?
Now you have me worried, is there something newer than this year's QS?
Thanks! I needed to know if someone else connected to a QS system. There has to be something else wrong, as I can connect using Telnet with the default (lutron/lutron) or the new dealer Login/Password, but not through AMX.
Thanks again for everyones post!
I did my first QS system about a month ago, duet module works fine.
Try log in "lutron"
password "integration"
The trick is that you need to read the data from the lutron device and when when it asks for login you send it, same for the password.
Btw, if you need help, then paste your code
The login logic is not the issue, it is the same as RA2. We believe there is something wrong with the Lutron or AMX processor. I will post next week.
