Symnet 8x8 DSP
 rmjsts
rmjsts
                    I am taking over an existing system that includes a NI2000 and a Symnet 8x8.  The symnet handles all audio routing and volume controls or all zones.  I have not ever used one of these before.  The NI2000 ethernet port is flakey and we are looking at replacing with a NI2100. Original programmer of course did not leave source code, have not been able pull the TKN file out of it, so looking at writing a new program.  I found a Duet module for it but not sure how to use it for volume ramping or switching commands. Been looking all over Symetrix's site and cannot find an actual RS232 protocol guide that shows all commands including switching and volume controls.  Not sure at this point I can write a program to control switching an volume controls.  Does anyone have experience with these?  I am signed up to complete their online trainng and will do so, probably this weekend, but list of courses does not look like there is any coverage on this info.  I have been able to use FileZilla to pull IR files down from the NI2000, but they appear empty when i open them with IREdit.  The only files i see listed on master are the IR files, no other files show. Am i missing something to find the TKN?  This is my first time replacing a controller without having the program available to me.
Any assistance is highly appreciated.
Thank you
Thank you
http://www.amxforums.com/showthread.php?8963-download-code-from-a-Master&highlight=prog
Sent from my iPhone using Tapatalk - now Free
Read the HELP files on EXTRACT in IREDIT if you want to get the IR files out. It's a hoot. Works, but OMG. Also beware trying to do advanced work in IREDIT (like editing!) using anything newer than Windows XP. You'll watch plenty of fast exits to the desktop.
Don't let children play nearby you when using IREDIT in general. They're likely to be exposed to some really foul language. If there is one AMX app that deserves a fresh start, it's IREDIT.
Also, I think all of the serial commands are in the help system for the symnet program. From what I remember the protocol is fairly easy to deal with.
Thanks guys, I am going to try to copy the TKN from the CF Card in the NI2000 and paste to the CFCard in the NI2100 and see if the program runs correctly. If so I am OK, beats trying to replicate the original program and try to match the Touch Panel, too much feedback involved to be able to this effectively. I am not sure I want to write a new program for this either. Customer is used to the inferace and feed back, and if I write a new program some of that is likely to change. especially with my limited knowledge of the Symnet protocols.
Actually i just completed copying from old 32mb card to the new NI2100 512 mb card. All works and is much faster. While looking in the old card I found the the axs source file(although does not show in NS receive function, comes up empty), but it is password protected. Original tech is nowhere to be found to have him open the file or remove password. Guessing no way to get past that, even via AMX tech support.
There are programs and services for hacking that kind of thing, but unless the password is short or a common word, it would be faster to rewrite the program.
