Sony EVID70 Module Rs232 Daisy Chain Question
Hi All,
Hope someone have done this before. 4 group of 2 daisy chain camera. I understand by reading the module information files that you need 2 com ports when you do daisy chaining but in the module information there's a note explaining that this functionnality have not been tested.
Someone been able to control those camera in daisychaining without using 2 com port or i really need 2 com port to do the trick.
i have no camera yet to do the test.
Thanks all
Thanks all
I've never used the module from AMX but you do not need two com ports to control those cameras.
I think if you read closer, the module documentation is talking about having more than one port on the Duet virtual device, not more than one com port. So instead of 5001:1:0 and 5001:2:0, you would have 41001:1:0, 41001:2:0, with 1 camera being controlled on 41001:1:0 and the second on 41001:2:0, etc.
Here's a part of the document
They explain to connect the first camera input on a port and the last camera output on another port. It's not a problem for me to do it that way but we going into a wiring issue.
Yeah the Sony documentation is written to suggest that you need a loop, but you don't actually need a loop. You do need to have five conductors between cameras you daisy chain, though not between the first camera and the controller.
Thanks for the info.
Best Regards
