Duet Issues
d_gavin
Hey all,
Does anyone know what the hell is going on here in this attachment?
This is from a new NI-3100 out of the box with a new install of Netlinx studio as well.
Master FW = v4.1.403
Device FW = v1.30.10
Cheers!
Cheers!
I Just got the impression from your post that it was straight out of the box from AMX.
I can see a Virtual Keypad and a Sony EVID camera or two.
It's probably an issue with the Duet libraries in firmware not matching the Duet libraries in a module so a firmware update could fix it but i doubt it, more likely old firmware will fix it.
Try commenting out all the Duet modules and see if you get errors, then add a duet module at a time and test.
Sent from my iPhone using Tapatalk
As a side note, even after successfully installing the latest Duet Runtime the current version of WebUpate appears to have an issue in that it does not detect this installation as being completed. As such, it will continuously show that there is an update available. If you want to check that it's all there however just have a look in C:\Program Files (x86)\Common Files\AMXShare\Duet\bundle. If you have the v2.0.x libraries you should see a few new libraries in there (including snapirouter2).
Cheers guys.
What is showing in your C:\Program Files (x86)\Common Files\AMXShare\Duet\bundle directory?
P.S. this is currently being looked into by the team at HQ.
Kim, A picture of my bundle folder is attached.
The issue with WebUpdate is now all fixed if anyone else is experiencing that. Simply the Duet Platform Runtime installer that it now pulls down and this will correctly show as installed.
Regarding your issues Gavin, if you are saying that there appears to be functionality broken with a specific firmware release give the support guys a call as I'm sure they would be interested in looking into this further.
