NetLinx Studio v3.4.908
For those who may not yet be privy, there's a new version of NetLinx Studio:
[B]NetLinx Studio v3.4.908[/B]
FEATURE - Support for the new TP5 Touch Panel Files (G5 Panels). Ability to add
TP5 files to the NetLinx Studio Workspace and the ability to transfer to the
new panels.
FEATURE: Support for the new Driver Design Module files (.xdd). Ability to add
XDD files to the NetLinx Studio Workspace and the ability to transfer to the
masters controllers.
BUG FIX - Corrected the problem of the NetLinx Compiler not reporting the correct
file name when displaying the #WARN compiler directive within NetLinx Studio when
the #WARN directive was located in an include file (.AXI). The NetLinx Compiler
Version is now [2.5.2.300].
BUG FIX - Reactivated the "Check Port Status" menu item within the Online Tree.
BUG FIX - Corrected the problem of exporting AXS/AXI files to an AXW file when
the user selected to "Exclude" these files from the export.
BUG FIX - Resolved the problem of transferring files to Axcent controllers.
I am happy about the #WARN fix, but sad that it breaks again if you have an include in an include...
Have you noticed any additional changes/bugs with this release?
    My favorite -- the ability to pull the TKN from the master. While I know you could do it in v3 firmware quite easily with FTP, it was broken (ahem, fixed) in v4 firmware.
  • jjames wrote: »
    Oh great! I didn't notice that. That's definitely going to make life easier when the code is mission-critical.
  • Before I install this;
    has anyone had any problems that would cause issues with existing code?
    I did notice that VERSION must now be a keyword or name of a data structure now. I had a module that used a constant named VERSION and upon compile with the new NS threw an error. I changed the name of the constant to. VERSION_REQUEST and all was well.
    Reminded me of the days of updating AXCESS code where everyone used the word SWITCH for a device and/or variable name for a audio/video switcher.
  • ericmedley wrote: »
    No, this must be a bug. If VERSION is defined as a CONSTANT I get the error "C10206: STRUCTURE type [CHAR] already defined". However define it as a variable and it compiles fine.
  • Just noticed two new registry entries under "KIT Files": "HttpServerPort" and "HttpServerSelected". Anybody know if the URL updating of touchpanels (described in this post) is also coming to firmware? Or perhaps enter a URL (such as amx.com/firmware) to get a list of the most current firmware?
    Nevermind. Just noticed the option and help text box in the Firmware Transfer Preferences.
    Perhapso. Either way it broke my code and either way it needed fixing. :)
    To be honest it surprises me that stuff like this doesn't happen more often. There are several under-the-hood variables and structures in Netlinx that could horse a persons code up.
    FYI - I tried using VERSION as a constant in build 600 of studio and had the same error - so it's not a compiler issue as the compiler changed only in 908. Build 525 (release) and 600 (TN 999) had the same compiler that hadn't been touched in years.
  • jjames wrote: »
    Ah, gotcha. So Eric, I guess you haven't been using the hotfix version.
