Netlinx stops sending UDP data at $00 (hex)
Hello,
i´m trying to send a hexadecimal command through UDP port with Netlinx, and it seems that Netlinx stops sending data when it reaches a $00
For example:
I open the UDP port:
ip_client_open(dvCamaraVisca.PORT,'192.168.1.54',52381,IP_UDP_2WAY)
and then send the string
send_string dvCamaraVisca,"$01,$00,$00,$06,$00,$00,$00,$01,$81,$01,$04,$00,$03,$FF"
At the "Diagnostics" i can see that the master just sends $01
And if i try with other command like "$81,$09,$04,$00,$FF", it sends $81,$09,$04
Why?
Thanks for your help!!
For example:
Why?
