DVXes overheating
I've put in a 15 or 20 DVX switchers over the past year, all for the same client, and most of them are overheating to the tune of about 43 degrees C. Most of them still work OK, but some are just plain acting flaky: parts of code apparently not executing, switch device going online and offline, that sort of thing. It seems like a manufacturing tolerance thing, where some units tolerate heat better than others.
So, this is a two-part question:
1) Have you seen overheating in the DVX switchers? and 2) has it caused problems? Well, three parts: 3) what was the resolution, other than lots of fans?
Thanks.
Thanks.
Markus
