SEND_STRING 0 Max Length
I decided to maximize my string length that I send to diagnostics but I couldn't remember the max length, I searched tech notes and the forum here and couldn't find what I wanted either even though I know it has been discussed.
So after a quick test it appears the max length that diagnostics will print before truncating and appending ... is 236. I also found that if you copy the line printed in diagnostics you'll get more.
so to maximize a send_string 0 we can send up to a 210 character string. I was thinking it was 180 but 210 does sound a little familiar too.
edit:
I think I goofed up some where cuz now it seems the max string print able is 210 not 236.
MAX printable = 236 Netlinx uses = 26 (Line 98 (16:38:03):: ) Left for us to use = 210
edit:
MAX printable = 210 Netlinx uses = 26 (Line 98 (16:38:03):: ) Left for us to use = 184
