Threadpool problem
Anyone ever use a Threadpool in Duet? I am getting IOExceptions when the threadpool starts reusing threads to execute tasks greater than the number of threads in the pool.
(0000050263) Morpheus: Starting devicesdkrt.jar
(0000056025) Morpheus: Starting snapirouter.jar
(0000071844) Task 1 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000071850) Task 2 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000071855) Task 3 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000071859) Task 4 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000071864) Task 5 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000071868) Task 6 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000071872) Task 7 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000071876) Task 8 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000071881) Task 9 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000071885) Task 10 Started @ Mon Apr 07 09:05:17 GMT 2014
(0000073085) SNAPIRouter: UtilityComponent loaded
(0000073205) SNAPIRouter: ModuleComponent loaded
(0000073363) Task 1 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073366) Task 2 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073369) Task 3 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073372) Task 4 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073376) Task 5 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073379) Task 6 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073382) Task 7 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073385) Task 8 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073388) Task 9 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073391) Task 10 Complete @ Mon Apr 07 09:05:19 GMT 2014
(0000073412) Task 11 Started @ Mon Apr 07 09:05:19 GMT 2014
(0000073426) java.io.IOException
(0000073430)    at sun.misc.Unsafe.compareAndSwapObject (Native Method)
(0000073432)    at java.util.concurrent.locks.AbstractQueuedSynchronizer.compare
AndSetHead (Unknown Source, bco=9)
(0000073434)    at java.util.concurrent.locks.AbstractQueuedSynchronizer.enq (Un
known Source, bco=32)
(0000073436)    at java.util.concurrent.locks.AbstractQueuedSynchronizer.addWait
er (Unknown Source, bco=47)
(0000073438)    at java.util.concurrent.locks.AbstractQueuedSynchronizer.doAcqui
reInterruptibly (Unknown Source, bco=7)
(0000073440)    at java.util.concurrent.locks.AbstractQueuedSynchronizer.acquire
Interruptibly (Unknown Source, bco=27)
(0000073443)    at java.util.concurrent.locks.ReentrantLock.lockInterruptibly (U
nknown Source, bco=8)
(0000073451)    at java.util.concurrent.LinkedBlockingQueue.take (Unknown Source
, bco=18)
(0000073458)    at java.util.concurrent.ThreadPoolExecutor.getTask (Unknown Sour
ce, bco=52)
(0000073536)    at java.util.concurrent.ThreadPoolExecutor$Worker.run (Unknown S
ource, bco=21)
(0000073537)    at java.lang.Thread.run (Unknown Source, bco=16)
The tasks run but I get that exception for each execution greater than the number of threads. Here is the actual code I am using:
package com.ctsi_usa.duet.virtual.thread.dr1_0_0;
import java.util.ArrayList;
import java.util.List;
import java.util.Properties;
import java.util.concurrent.ExecutorService;
import java.util.concurrent.Executors;
import org.osgi.framework.BundleContext;
import com.amx.duet.da.NetLinxDevice;
import com.amx.duet.devicesdk.Utility;
public class VirtualThread extends Utility{
	private static final int POOL_SIZE = 10;
	private ExecutorService threadPool = Executors.newFixedThreadPool(POOL_SIZE);;
	private List futureList = new ArrayList();
	public VirtualThread() {
		super();
	 * @param bctxt
	 * @param nd
	 * @param props
	public VirtualThread(BundleContext bctxt, NetLinxDevice nd, Properties props) {
		super(bctxt, nd, props);
		Thread m = new Thread(new Runnable(){
			public void run() {
				doThreadPool();
		m.start();
	/* (non-Javadoc)
	 * @see com.amx.duet.devicesdk.base.Module#doAddNetLinxDeviceListeners()
	protected void doAddNetLinxDeviceListeners() {
	/* (non-Javadoc)
	 * @see com.amx.duet.devicesdk.base.Module#doNetLinxDeviceInitialization()
	protected boolean doNetLinxDeviceInitialization() {
		return false;
	/* (non-Javadoc)
	 * @see com.amx.duet.devicesdk.base.Module#isDeviceOnLine()
	public boolean isDeviceOnLine() {
		return false;
	/* (non-Javadoc)
	 * @see com.amx.duet.devicesdk.base.Module#isDataInitialized()
	public boolean isDataInitialized() {
		return false;
	private void doThreadPool() {
		for (int x = 1; x < 31; x++) {
			try {
				futureList.add(threadPool.submit(new TestRunnable("Task " + x)));
			} catch (Exception e) {
				e.printStackTrace();
And TestRunnable Class:
import java.util.Date;
public class TestRunnable implements Runnable {
	private String name;
	public TestRunnable(String name) {
		super();
		this.name = name;
	/* (non-Javadoc)
	 * @see java.lang.Runnable#run()
	public void run() {
		System.out.println(name + " Started @ " + new Date());
		try {
			Thread.sleep(1500);
			System.out.println(name + " Complete @ " + new Date());
		} catch (InterruptedException e) {
Anyone have any ideas?
    mighemighe Posts: 39
    sun.misc.Unsafe is an internal API tightly bound to the underlying os/hw for high performance operations, like atomic CAS, so an error risen there is usually a "bad thing"©.
    I don't think your code can cause the problem, it seems that something goes wrong in a lower level: if you run this snippet on a "real" JVM, do you get any error?
    JasonSJasonS Posts: 229
    Worked with no errors in JDK 1.7.
    package threadpooltest;
    public class ThreadPoolTest {
         * @param args the command line arguments
        public static void main(String[] args) {
            final ExecutorService threadPool = Executors.newFixedThreadPool(10);
            Thread m = new Thread(new Runnable() {
                @Override
                public void run() {
                    doThreadPool(threadPool);
            m.start();
        private static void doThreadPool(ExecutorService eService) {
                try {
                    eService.submit(new TestRunnable("Task " + x));
    TestRunnable class.
        private final String name;
            this.name = name;
        @Override
        public void run() {
            try {
                Thread.sleep(1500);
    Output:
    run:
    Task 3 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 6 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 10 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 2 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 1 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 4 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 5 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 7 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 8 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 9 Started @ Tue Apr 08 08:59:48 EDT 2014
    Task 3 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 11 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 10 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 12 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 4 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 13 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 7 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 14 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 2 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 15 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 8 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 16 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 1 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 17 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 5 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 18 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 6 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 19 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 9 Complete @ Tue Apr 08 08:59:49 EDT 2014
    Task 20 Started @ Tue Apr 08 08:59:49 EDT 2014
    Task 11 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 21 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 13 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 12 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 22 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 23 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 14 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 24 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 16 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 17 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 25 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 15 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 26 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 27 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 19 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 20 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 18 Complete @ Tue Apr 08 08:59:51 EDT 2014
    Task 29 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 28 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 30 Started @ Tue Apr 08 08:59:51 EDT 2014
    Task 21 Complete @ Tue Apr 08 08:59:52 EDT 2014
    Task 22 Complete @ Tue Apr 08 08:59:52 EDT 2014
    Task 24 Complete @ Tue Apr 08 08:59:52 EDT 2014
    Task 25 Complete @ Tue Apr 08 08:59:52 EDT 2014
    Task 23 Complete @ Tue Apr 08 08:59:52 EDT 2014
    Task 27 Complete @ Tue Apr 08 08:59:52 EDT 2014
    Task 26 Complete @ Tue Apr 08 08:59:52 EDT 2014
    Task 28 Complete @ Tue Apr 08 08:59:52 EDT 2014
    Task 29 Complete @ Tue Apr 08 08:59:52 EDT 2014
    Task 30 Complete @ Tue Apr 08 08:59:52 EDT 2014
    BUILD STOPPED (total time: 22 seconds)
    What I have found from research online it seems like the ReentrantLock class throws that Exception when a Thread tries to release a lock it does not own. I have submitted this to AMX but it will take awhile to hear back form the Duet guys that we mere mortals are not allowed to interact with directly. I imagine that there response will be something like "the code still runs what are you complaining about?"
    JasonS wrote: »
    when you try to unlock a monitor you don't own, an IllegalMonitorStateException is thrown, but in you case we have an IOException from the Unsafe class... that's why I feel there's something wrong somewhere down into hidden system layers
    Good luck :-P
