Programming Touch Pannle FeedBack
Hi Guys,
I have designed and Programmed touch panel. I have designed Toggle buttons to turn the lights on and Off. Everything seems to work fine. Though i Am stuck in Feedback statements.
Can any 1 help me with a sample code for feedback statements. I will Really Appreciate Your Help.
Am Attaching the code for the Touch Panel lighting control.
Are you asking about feedback from the different lighting devices to change the state of the button on the touch panel
Or
When you press a button - the button turns on when you send the on command to the devices and off when you turn the lights off
I really appreciate your reply Mate. I need to change the state of the feedback from the different lighting devices to change the state of the button on the touch panel.
and if you could help with the second condition you stated. It will be great
Thanks in advance
The feedback to the touch panel when you press the button can be done this way (using your first button as an example)
BUTTON_EVENT [dvTPLIGHT, 1] { PUSH: { IF (BFDIL1 = 0) { SEND_COMMAND dvGFDIM1,'P6L100T0' BFDIL1 = 1 } ELSE { SEND_COMMAND dvGFDIM1,'P6L0T0' BFDIL1 = 0 } [dvTPLIGHT,1]=BFDIL1 // This sets the button state the same as BFDIL1 value of 1 for on and 0 for off } }You need to make sure that the button is set to 'CHANNEL' feedback in the touch panel design.Cheers Rob
