Sharp LED PNL702B not responding
Hi,
I was using amx duet module to control Sharp PNL702B LED..everything was working perfectly fine but suddenly nothing is working. TV is not responding. I checked all the cables but not able to resolve the issue..its a interactive TV.
Any suggestions please...
Sent from my Nexus 4 using Tapatalk
Sent from my Nexus 5 using Tapatalk
It seems that it will take the command either way for a second or so after power off, but once it has been off for a few seconds, needs the spaces leading the value rather than trailing. This also applies to the 80" interactive model.
Hope this helps,
Don
EDIT: There are 3 spaces between the 'POWR' and '1', the board seems to have truncated them to a single space.
