Netlinx Studio integrated "file transter" won't open!
Torbidoni
When I press to the "file Transfer" icon on the toolbar or on menu :"Tools -> File Transfer", I receive immediatly an error message (see attached pictures).
I'm using NS rel 3.4.908 but the same error was already present on the previous release (the software update didn't solved).
The file transfer has always worked, but, I can't recall why, I started to see the error message in every attempt to run it.
I can run File Transfer 2 without problem, and I also checked in the windows (OS=win7 64bit) registry to see if there was something wrong, even compared with the registry of another PC (that was working fine).
I can't find the cause ! Do you have any suggestion ? Probably if I delete (uninstall) the current release and I install it again I have a good chance to fix it, but this is the last test I would do.
Thanks.
Thanks.
So the complete "story" is this :
1) I was working with NS 3.3
2) From one day to another, the File Transfer stops working
3) I updated from 3.3 to 3.4.908 (I don't recall how, maybe using Web Update)
4) The File transfer still non working
5) I've tryed to reinstall 3.4.908 over 3.4.908 using the file
6) Still the same.
Maybe, yes, it's time to remove NS.
NS 3.5.908 removed from system (uninstall) and then replaced with NS 3.5.960 and.......nothing changed, always the same error while I try to open the file transfer.
What's next ? "Format C:" ? :-o
I'm not pretty sure about the uninstalling test because after the reinstalling I've found all the settings I did in the old NS, so maybe not all the file and settings have been removed !
About the DLL, that's what I think one of the main cause like something on the registry: That happened after installing some other software ? I don't remember exactly, but, to have an idea, I install new programs/drivers at a rate of about one or two per week, for testing or just to "talk" with new devices.... Maybe one of the monitor/mixer/switcher driver caused the issue on a NS dll. Do I have to clean the system registry after NS uninstall ? Do I have to uninstall ALL the AMX software on my PC (hope NO, I'll never find the time) ?
Thanks to all for the answers.
