NXT-CV12 reset problem
in AMX Hardware
I took a functioning CV12 and installed a new touch panel file in it. Everything was working fine until I had to make some changes. The new changes were taking a long time and finally wouldn't accept them. So I did a reset system settings to see if that would fix the problem. It ended up deleting all the words in the setup page. Only the bubbles are showing with no words or numbers in any of them.
Any ideas on what happened and how to fix this?
If you are still connecting to netlinx master then do a full panel transfer with system files and that should reload the setup pages. If it doesn' then next I'd try reloading firmware.
And if you are not connecting from the panel to netlinx over ethernet, then you could try running a temporary ICSNet patch (if your master is one that supports this).
thanks,
Something to try if this transfer fails or lags out.
