NI3100 Watchdog
Hi all
im hoping to set up a watchdog from a security system to let me know if something happens to the security system,
i currently have the two systems communicating via RS232 so i can send the 3100 a string every 5mins from the security i just need to write the code for the 3100 to send me an email if the other system goes down.
    reeco81 wrote: »
    Hi all
    sounds like a plan
  • GregGGregG Posts: 251
    Check out the new built in email command for the latest netlinx firmware:
    SMTP_SERVER_CONFIG_SET(SMTP_ADDRESS,'mail.amx.com')
    SMTP_SERVER_CONFIG_SET(SMTP_PORT_NUMBER,'25')
    SMTP_SERVER_CONFIG_SET(SMTP_USERNAME,'john.doe@amx.com')
    SMTP_SERVER_CONFIG_SET(SMTP_PASSWORD,'mypassword')
    SMTP_SERVER_CONFIG_SET(SMTP_FROM,'john.doe@amx.com')
    SMTP_SERVER_CONFIG_SET(SMTP_REQUIRE_TLS,SMTP_TLS_TRUE)
    Timeline_Event[TL_SECURITY_REPLY_CHECK]
      If(nNoReplyForALongTimeFlag)
        SMTP_SEND(0:3:0,'jane.doe@acme.com','Security Alert','The security system is offline... again!',NULL_STR)
    GregG wrote: »
    Which latest, V4 for NI or 1.x for NX?
    I know 4.x had it - haven't tried it on the NX yet, but hopefully they still have it.
  • reeco81reeco81 Posts: 4
    ericmedley wrote: »
    sounds like a plan
    Any ideas???
    GregG wrote: »
    Thanks Greg
    I have got the email part working already from inputs changing state, its just the watchdog part im having troubles with
    reeco81 wrote: »
    Any ideas???
    The suggestions above will do exactly what you want. That is how you can send yourself an email notice based upon whatever code you write to monitor the security system.
    I usually include this feature whenever I write security/fire/medical/access software. I pan on emailing the client, myself or both.
    Ahh yes i missed that bit
    cheers
