LUTRON RadioRa2 Keypad event
Hi,
I'm working on a new project with a RadioRa2 and a Keypad.
But I can't find how to receive the event from the Keypad.
I can set the light level, so the com between the master and RadioRa2 is working.
vdvLutronRadioRA2 		= 	41001:1:0
dvLutronRadioRA2 		= 	0:3:0
DEFINE_CONSTANT
VOLATILE CHAR sKeypadAddress[20][20] =
    '6:B1', 	//Keypad1 Button 1
    '6:B2',	//Keypad1 Button 2
    '6:B3',	//Keypad1 Button 3
    '6:B4',	//Keypad1 Button 4
    '6:B5',	//Keypad1 Button 5
    '6:B6'	//Keypad1 Button 6
VOLATILE CHAR sLightAddress[20][20] =
    '7:D1',    	// Dimmer 1
    '8:D1',   	// Dimmer 2
    '9:D1'   	// Light Test
DEV vdvDev[] = {vdvLutronRadioRA2}
INTEGER nLutronRadioRA2 = 1
INTEGER nLutronRadioRA2Pages[] = { 1 }
INTEGER nKeypadSystemPages[] = { 2 }
INTEGER nModulePages[] = { 3 }
DEFINE_MODULE 'Lutron_RadioRA2_Comm_dr1_0_0' comm(vdvLutronRadioRA2, dvLutronRadioRA2)
DATA_EVENT[vdvLutronRadioRA2]
    ONLINE:
	WAIT 50
	SEND_COMMAND vdvLutronRadioRA2,"'PROPERTY-IP_Address,192.168.33.101'"
	SEND_COMMAND vdvLutronRadioRA2,"'PROPERTY-Login,lutron'"				// lutron
	SEND_COMMAND vdvLutronRadioRA2,"'PROPERTY-Password,integration'"			//integration
	SEND_COMMAND vdvLutronRadioRA2,"'REINIT'"
CHANNEL_EVENT[vdvLutronRadioRA2,0]
   ON:
	 send_command vdvLutronRadioRA2, "'LIGHTSYSTEMLEVEL-9:D1,100,2'"
So the Chanel_event is not working, can anyone help me with this part?
Thanks for your help.
  • if you read at the word document LurtonRadioRA2 interface you can see that the only channel used on the virtual device are for the setting of a third part HVAC.
    You have to use the event string in your data_event of your virtual device to have the feedback of your keypad.
    You can use the command ?KEYPADSYSTEMBUTTONSTATUS-<address> to get the status of the specified button.
    example:
    send_command vdvLutronRadioRA2,"'?KEYPADSYSTEMBUTTONSTATUS-7:B1''"
  • CedricCedric Posts: 32
    Thanks for your reply
    So I have to add:
    String :
        FIND_STRING(DATA.TEXT,'KEYPADSYSTEMBUTTONSTATE-7:B1,CLICK',1)
                //execute the action
    But where should I put the send_command vdvLutronRadioRA2,"'?KEYPADSYSTEMBUTTONSTATUS-7:B1''" ?
  • You can use a timeline to request the status of each button but maybe the module will send you the feedback without the need to trigger the status of each button.
    It's not working and I had try also directly
    String :
    And nothing is happening
  • Notifications ?
    Do you have message in your notification bar regarding the lutron virtual device ?
    You should see someting when you click on your lutron keypad
    have try the first and second button and receive this message :
    Line 1 (17:53:36):: Command From [41001:1:1]-[KEYPADSYSTEMBUTTONSTATE-6:B1,PUSH]
    Line 2 (17:53:36):: Command From [41001:1:1]-[KEYPADSYSTEMBUTTONSTATE-6:B1,RELEASE]
    Line 3 (17:53:43):: Command From [41001:1:1]-[KEYPADSYSTEMBUTTONSTATE-6:B2,PUSH]
    Line 4 (17:53:43):: Command From [41001:1:1]-[KEYPADSYSTEMBUTTONSTATE-6:B2,RELEASE]
    So I might use the ''COMMAND :''
    Withe FIND_STRING(DATA.TEXT,
    Yes, Duet modules return a Commands unless otherwise instructed to do so.
    Yes Had learn this today first time using feedback part of a module.
    If someone had the same problem
    here is the code :
      command:
        if(FIND_STRING(DATA.TEXT,"'KEYPADSYSTEMBUTTONSTATE-6:B1,PUSH'",1))
    	 REMOVE_STRING(DATA.TEXT,"'KEYPADSYSTEMBUTTONSTATE-6:B1,PUSH'",1)
    Cedric wrote: »
    here is the code :
      command:
    	[b][I] REMOVE_STRING(DATA.TEXT,"'KEYPADSYSTEMBUTTONSTATE-6:B1,PUSH'",1)[/b][/I]
    Why are you doing the remove string? string manipulation is a pretty spendy process. why bother if you're not doing anything with it?
    you are right it's useless
    I was thincking of remooving and just keeping the id for switch/case but not sur if I really need it also.
    Cedric wrote: »
    here is the code :
      command:
    You might want to make your code more generic. I split the feedback into multiple parts so I have a variable for the command (KEYPADSYSTEMBUTTONSTATE), for the ID (6), for the type(B) and the button number (1), and the event (PUSH). I don't always need this level of granularity, but when you have a large house with a mixture of keypads, dimmers, shades, sensors, etc, you can more easily identify what's going on.
