line feed into _WC function
hi, is possible insert a line feed into a string pass to _wc function. i try with different combination but notihing...
_WC('hello world')
how insert a line feed after hello?
thank's
  • rfletcherrfletcher Posts: 217
    Daniel79 wrote: »
    _WC('hello world')
    thank's
    I'd think _WC("'hello world',$0A") should work
  • no.. doesn't work i try different combination ... , i think is a _WC function limit
    this function alow only a char string and return a widechar
    Daniel79 wrote: »
    Can you use ch_to_wc() instead of _wc? Because _wc does only work with string literals according to the documentation. Alternatively, maybe try \n where you want a linefeed? That would be the escape for a line feed in C, but I can't seem to find the documentation for what escape sequences are in NetLinx for some reason.
