Home AMX Technical Discussion
Set Retangle, Embedded ^BMF Does NOT Work For Buttons On Subpages
I have a ModeroX G4 panel with firmware v2.104.54. Trying to use the embedded ^BMF command to set a rectangle size(button size) of a button on a subpage and it does NOT seem to work. The show/hide command(%SW) works but NOT (%R).
Has anyone experienced this problem?
  • nickmnickm Posts: 152
    I have. Its been reported to TS, but I doubt at this point it will get fixed.
    Yeah, I'd guess not likely - especially since ^BMF is not in the new G5 panels either
  • The redraw command works on sub-pages once the sub-page is anchored. The co-ordinates you send with %R reference the base page not the sub-page where the button actually is located - this is the same for popup pages.
