Dead 9000i
                    I have an MVP-9000i that has been booting now for 3 days.  It is stuck at the AMX logo with the scrolling bar at the bottom of the page.  Any ideas other than sending it in for service?
Do you have another panel available to clone a CF card from?
1. Reboot the device, either from the Setup page (page 50) or via the Reset button on the left side of the
device (FIG. 2). Touch and hold the touch panel while the device is rebooting, until the “Request for
Factory Reset” confirmation screen (FIG. 108) appears. The Status LED on the right front of the device
(FIG. 1) will also change color from blue to red.
2. Release the touch screen to start the factory reset. The factory reset confirmation screen appears, warning
that continuing with the reset will result in a loss of data (FIG. 109), and the red Status LED will blink on
and off. Press Yes within 10 seconds to continue with the factory reset, or No to continue the reboot with
the current settings and firmware.
Danny
That said, stalling on the logo screen generally means the firmware image is damaged. If there is no CF card, it is probably going to have to go in.
Might be the WiFi card. Any of that "extra stuff" look like an antenna?
You are right. There are two connections that look like the are part of an antenna system. I found (hidden under a metal shield) a 2GB Micro SD card as well.
MLO
u-boot.bin
uImage.bin
Danny
I'll give that a try.
Danny
