NX1200 IOs stuck high
Has anyone had any issues where an NX master's IO remain high after receiving a pulse command? It is staying on even after sending it an OFF command. Code is as follows;
stack_var integer nloop
Pulse [dvMaster_IO,1]
Wait 10
Sys_Started=1
For (nloop=1;nloop<=12;nloop++)
SEND_STRING dvBose,"'SA"#Rm',ITOA(nloop),'">2=0',13"
Roomstat[nloop].Recording=1
Roomstat[nloop].Paused=0
Off [dvMaster_IO,1]
  • How are the IO's configured?
    Did you configure the IO's at all?
    Look up SET INPUT in the AMX PI
    Try TOTAL_OFF[dvMaster_IO,1] . I'm sure someone can chime in on the details I've forgotten, but there are cases when you can turn a device off, but the feedback doesn't follow.
