Samsung LCD TV RS232 Protocols
Jorde_V
Been trying to find them, have found some. But I'm curious if they also hold true for the LE40A656 series and the LE32A330 series. I've found this protocol posted here by the guy with the One Piece avatar (Luffy), sorry that I don't remember your name :P.
(check attachment)
(check attachment)
Thanx
I used this spreadsheet to program a Samsung UN40H5203 I bought a month ago.
I've seen 2 different protocol types for Samsung TVs in my search. The PDF you attached is inline with the attached spreadsheet.
The spreadsheet is a little more straight forward (and a bit robust).
I poked around changing just the command byte and found some more updated codes that were not included in the spreadsheet (SMART TV functions and such).
There were some that I know work for different menus by I really only gleaned these from the main menu screen.
If you're really interested, I can post the Netlinx module I wrote for it, but for now I'll attach the spreadsheet.
The commands I posted do generate replies, but they seem to be fairly inconsistent hex strings.
I suspect there might be a problem with the RX on the port. I'll know for sure this weekend when I get a replacement unit. The original one has a dead pixel in the middle of the screen, hardly noticeable, but knowing it's there is enough to make me want a replacement.
From what I've seen all you get is a yay/nay hex string. I can't remember what the characters are off the top of my head but there was no quantitative feedback from these, just a thanks or no thanks.
Yes, I agree. Just a whole lot of $FFs with a smattering of other hex bytes. I first thought it was my display, but I received a replacement and the responses are the same.
