Port/Device/Virtual Device Limitations?
                    Working on a system that has a good amount of stuff involved, and I'm trying to connect everything to RMS.  I'm having some problems and I'm wondering what are the limitations on an NI-3100 processor? or any other one for that matter.  Just a general question.
In my online tree it shows at the bottom left, number of Masters/Devices/Ports. Are there limits on any of these? I think probably Masters, limit = 200, right? but what about Devices/Ports and Virtual Devices or Java Modules (I know with modules, it depends on how complicated they are) but has anyone run into limits on any of these, a number that they just know isn't allowed and won't work?
Any input is appreciated.
PS. What I'm trying to control and/or monitor with RMS:
4 Cisco Codecs, 22 Planar displays, 10 Samsung displays, blu-ray player, 2 cable tv's, 2 satellite boxes, Qsys DSP w/ 4 phone lines, 3 matrix switchers, 4 touch panels, and 2 other IR devices
Javed
Javed
You should check your cpu usage and memory usage, and probably need to allocate more duet memory if you have a lot of java modules.
Javed
