TPDesign 4 Bug
Has anyone else seen this..... If you overwrite the default channels on a Modero Viewpoints External buttons, download the panel, push the buttons, you get a different channel on the push. Sometimes it might be the default channel set or it might be the channels from a completely different page.
From what I can tell, if you overwrite the default channels on external buttons on one page, and you copy that page and rename it, thats where the problem begins. If you reassign the external buttons on the copied page. it doesn't always work. If you look at the function maps, the function numbers will be wrong as well. The only way I see to fix it is never copy pages, but create new pages. Then the function numbers will be inline.
Kerry Myers
Dave, do you see this when pasting pages/buttons within the same panel, or across multiple panels?
Another problem is when TPD4 looses communication to a system when you are connected and the application is minimized, you get your workspace scrambled?not cool. Does anybody know if this is being addressed?
Robb W
