Satellite Radio
Does anyone know of an XM or Sirius tuner that has RS232 or IP Control. Basically I want what the ADA Tune-Suite offers, but I am not sure that we can support bringing in the entire ADA line for one piece. Any ideas?
Here is a link to three models.
http://www.sirius.com/servlet/ContentServer?pagename=Sirius/CachedPage&c=Page&cid=1066068011203
Antex (www.antex.com) makes both Sirius and XM multi-zone tuners ideal for integration with Netlinx. Their triple-play units are 3 zone Sirius or XM (no mix and match). They have an RS-232 port and a very nice protocol (I did a Netlinx module for it and worked with them on asynchronous message extensions to the protocol). The units rack or shelf mount and are designed for the integrator marker. Reference modules and TP files are on InConcert.
ADA also makes an XM tuner for their TuneSuite product - not sure about whether they have or will have Sirius support.
Hope this helps.
Also, forgot to mention in the previous post that Sirius support in the Escient Fireball products has been discontinued. Escient and Sirius had an arrangement for access to Sirius radio streams but Sirius decided to move to a different subscription model and Escient had to change directions. Escient announced at CEDIA a new streaming radio format (Radioio) to replace the Sirius streaming capability..
Thanks again,
Pretty cool as it has a video out to show all the info on screen
Kevin D.
P.S.
My boss absolutely loves his satellite radio in his car and he loves it. So, everyone hears what they want.... just like some people think a cheap plasma looks as good as a Fujitsu
It has been, and continues to be proven that more people would prefer a quantity of mediocre quality than a smaller amount of high quality.
XM and Sirius could bring their quality up to a closer-to-CD level by cutting their amount of channels in half thereby doubling the amount of bandwidth deliveing the remaining channels. They both announced that they will be doing that when pigs become visible flying over the moon.
My 128-192K MP3 CDs sound worlds better than satellite radio. They are what I will be listening to at least for the near future.
My 2 cents.... OK, 3.
I have just put one of these ( XRt12 ) into a clients house and love it so far but am running into a little issues. Working with Polk audio Tech support getting it worked out. I would reccommend this to any one because its not all that expensive.
Yeah good luck with that. Let me know if they do anything other then the Jedi mind trick "no your not having that problem".
I've talked to the head of the tech department last year at CES, I've bombarded my rep, etc.. No help.
Major problem is that as soon as you send any RS232 string, it resets the video information to the center of the screen. It takes a while for it to start jumping around again(to avoid burn in). Well if you request song/channel info every 30 seconds or so the text is always centered on the screen. The will burn a POLK AUDIO logo into any plasma pretty quick.
I requested that data REQUESTS to the unit not change the screen-saver timeout. I was told they didn't have that issue and to upgrade the firmware. Well we had a first run unit that couldn't be upgraded via RS232. So they send a new unit out as replacement.
The new unit DOES THE SAME THING, and on top of that they changed the way they terminated the feedback. So I had to go in and change my code to again get channel /song feedback. I asked them if there was a way to change the feedback back to the old way and was told "we never changed it, it must be something in your program". The only thing that changed was the XM unit, but it must be my fault.
Sorry for the rant. I've had to just put the display on the "off except when changing" mode and keep the front of the unit out of reach.
Kevin D.
Yeah I am noticing that the tech support isn't the greatest. I have called them twice and sent two emails with no luck. All I wanted to know was two simple things but haven't heard back from them yet.
1. Wanted to know if there was an rs232 command to switch between direct / preset mode
2. Wanted to have a direct channel input via rs232 so if you hit 1 2 3 it would go to channel 123
On the second one I cheated a bit and did that part via ir works a little but not all that great . Still waiting to hear back from them on that one considering when I talked to tech support they siad it wasn't implemented yet.....
Thanks for the info Kevin.
Cheers
Chris Ondrovic
Just have a pop up keypad and parse the channel number after they hit enter:
